Hi everyone,
Just wanted to test the waters and see if there is anyone interested in trading down for my civic with money your way. Thinking of getting back into the seat of a nissan again as a weekend car. I barely get a chance to drive my little honda around and only have time to drive during the weekends, so I thought I'd splurge and get myself a fuel-guzzling, fuel inefficient, car. Here's some info about my car:
Car: Honda EK Civic 1997 CXi/Vtir
Mileage kms traveled: 107,000 kms
Extra Comments:
- jap spec si b16a conversion
- ek4 brake upgrade (replacing cxi rear drums)
- civic type r flywheel
- exedy heavy duty clutch
- tein ss coilovers (2200 kms travelled)
- ngk iridium spark plugs
- custom 2 1/4 inch cat back system with a high flow cat
- oz spec itr headers
- front and adjustable rear whiteline swaybars (with rear re-enforcement kit)
- honda access front lip
- ctr replica rear lip
- color coded moulds (bumper and side) and mirrors
- custom sri with highflow panel filter (courtesy of Bennjammin)
- bride replica seats
- skunk gear knob
- el dials
- DIY ctr headlights
- Pioneer DEH P8650MP Head Unit (less than a year old)
These are all the mods I can remember. Car is fussed over by myself as most people who know me can confirm. Oil is changed every 5000 kms and the condition of the car is very good for its age. Recently dynoed at 101.4 kws atw (by hypertune in Taren Point). An aftermarket computer will apparently increase this by 10+ kws as my car is running a tad rich at the moment.
Selling price will be $13000. So whatever the difference between ur car and this price, I will pay in cash.
Contact Details My mobile is: 0413 569 075. You can also email me using the following email address: [email protected]
Here are some photos:
Thanks for looking.
Regards,
Fernando.
Edited by spacepants_fb
swap for r33 gtr white in color with quite a few mods
done to it
Sorry catzilla, I'd love to trade with you but I'm afraid an r33 gtr is out of my price range. I'm looking for a car under $20 000. Thank you for your offer anyway.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
