Hello all,
Organising a meet and movie to see 2 Fast 2 Furious @ Dandy Drive ins on the 21st of June... Lets make this a big one! Tell one tell all.
Gonna follow the plan from the last drive ins cruise so meet at Dandenong Stock Yards @ 6pm, meet & chat then onto the movie @ 7:30 (starts at 8:30 - gates open 1 hour early).
I recommend that people bring food and drink because stuff is quite expensive there (unless Vickii brings us all food again :P).
I will speak to the cops before hand and promise good behaviour in exchange for no trouble. It was fine last time. And from what I have heard there was no trouble at Coburg on opening night.
Let us know if you're coming. Do people need directions again?
Coming so far (assuming cops don't bother us):
- MaXiMuS007 (with his car back)
- HotSky
- DJ_L3ThAL
- MzDeFecTeD
- 32_envy
Interested:
-RedLineGTR
-Al
(P.S. Not hijacking JET-33's gold class nite, but drive ins are cooler so come to both!)
its awesome
the 34 is fkn NUTZ!
even if u ring the cops, it doesnt matter, theyl just say theyl leave u alone and b there in unmarked cars/clothing...take down plates..and send out letters...
especially at dandy...its like a few kms from the illegal drags which they r currently goin double nuttz on and im tippin its a sat nite too..?
hmmmmmmmmmmmmmmmmmmmmmmm
Hrmm so is any1 still coming?
The whole point of this for me was to celebrate getting my car back but as that has been delayed i'm not even in the mood to go any more *cry*
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
