Got some spare bits after some more work.
Excuse the sales guff from my ebay description for the punters.....
As sold by www.uniqueautosports.com, a standard rb25det manifold modified to suit an external wastegate setup. The standard units flow big horsepower no problems and doesn't crack and break like the stupid wank stainless one I have had to have to fit to suit a very large turbo. I previously used this with a GT35 and it fitted my R33 with no mods other than another flange spacer. Oh how I wish I could go back to cast iron..... The flange has been cut off so you can weld on whatever flange/vband you need. From the above supplier they retail for $690 although they do charge like wounded bulls (there service is great!). I made nearly 300RWKW with this setup (the pics shows an older turbo setup). FREE ADVICE, even after spending $800 (wholesale) bucks on a supposedly decent stainless manifold they still can crack! Keep to cast or get some mild steel ones made up by someone decent.
$250 no offers
Standard Intake manifold off a S1 R33 Skyline GTS-T. In good condition (not sure how you would wear one out actually) and comes with the expensive gasket under the plenum (in GC) and bolts etc. Perfect for someone who wants to custom make a front facing throttle body setup.
$150 no offers
RB25DET Throttle body. Good condition. Good for replacement or upgrade!
$50 no offers
Please no stupid questions.
First in to PAY get them.
[email protected]
Melbourne pickup or can organise post if I have too.
https://www.sau.com.au/forums/topic/175088-parts-to-suit-rb25det/
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
