Parts for a R32 GTST that are wanted
GTR fuel pump
Boost control like a Turbosmart single or dual stage
Modified computer or chip and socket for the following
Will swap standard and some cash if needed
No speed limit
No boost limit
New fuel map
New ignition map
Standard injectors
GTR fuel pump
Z32 air flow meter
Also someone to make up piping for a GTR intercooler to fit GTST
https://www.sau.com.au/forums/topic/17512-r32-skyline-parts-wanted-vic/
hey,
i have custom piping and FMIC for sale if you are intersted, made very good improvements over the standard unit, and helped me to run a 13 flat at calder without to many other mods on the car.......also a bomex style front bar and a set of plates PHAT-32......
Steve
just PM me or call em during the day on 0402 903 007
i can vouch for Dr_Drifts ECU :(
just look at my dyno sheet and the AFRs on it... 30rwkw improvement just with that and 2 more psi.
http://members.optushome.com.au/nikora/DYNOSHEETS.jpg
its a pity they didnt print out my original AFRs in the dyno at the bottom cause they were all over the place.
BTW this gets rid of ALL the cuts inc speed etc.
