Nice ceffy man very nice indeed very clean thoughout.
i might have to head back to the phillippines and drift for a holiday haha
Jase...
Hi Jason,
Drifting is still fresh over here. You may want to do some runs here when there is a competition and mostly, that is done from march to Sept.
  • 4 months later...
  • 3 weeks later...
Hey how is your conversion going. U said you will log all the process and take some pics. I got into a problem with my wiring.
Let me know if you have something.
THanks!
Here is a not so detailed work on my car. Sorry, I forgot to post it after I was done with it as I've been busy with work but here it is....http://www.cardomain.com/ride/2439676/4
I'm part Filo lol.
Yep fair few guys and gals who are in the import scene here.
Everything from skylines to evo's and even magnas with GTO twin turbo conversions.
Oh wow...now I feel at home in this forum...hahaha. :laughing-smiley-014:
  • 3 months later...
Haha your driveway looks so "filo"!
you should have broken bits of glass on the top of your concrete wall, rather than the pot plants hahaha
i'll be going back in Feb...can't wait!
...nice car by the way! :dry:
...nice car by the way! :huh:
Hahaha...only in the Philippines.
See you in March if you are staying here long. :D
...oh and how do u find driving a car with those rims and bodykit on such poor quality roads?
The roads here are mostly good and in concrete but just a little bumpy from the construction. The car can still manage it though I just have to choose where I am going.
coming along quite nicely dude.....buuuut...something has come to my attention, where has your chrome grille gone????
an another quick question, what size rims what size tires buddy??
Edited by TAKUSHI
Howd you go about painting the front grille? Im thinking bout doing the same, but not sure on how to achieve such a beautiful look! hehe.
I never did anything to the grille. It is still the way it is when I purchased it. I just try to keep the plastic scratch free all the time.
Hi. I have my chrome grille in storage and I use it once in awhile depending on my mood.
The front rims I have is 17x8, +5 offset and the rear is 17x9,+10 offset. Tires I use are 215x45x17 all around so the rears are pretty stretched.
I have a new set of wheels mounted to the car and I have yet to take new pics of it. Currently, I am using Rota Torques with a 17x9.5 all around, paired to 215x45's. The bodykit I have are already painted so maybe I will take new pics again and post it next week.
Thanks. :banana:
  • 1 month later...
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
