..and just incase anyone's thinking of asking,mine are looong gone :blink:
So go for Ragex's
PS, now tuned on a solid 246 rwkws, hitting low 80% and very rarely, heaps of room left.
Great cheap injectors for a very common/obtainable goal
Installation done myself.
Plugged in 82.5% correction on the Power FC hand controller and drove it for ages with no issues.
Felt like normal.
Waited for a few other upgrades to get sorted, dud Z32 Air Flow Meter etc.
Had it tuned by The Hitman in Penrith.
Unbelievable now, love it!
Just waiting to sort the clutch now.. :blink:
I purchased my 550cc injectors from Belgarage. They had them imported from Japan within a few days.
And these babies drop str8-in.
*pats his new s15 480cc injectors*
aye guys i have a bigger turbo plenum and good exhaust manifold high mount, larger exhasut 3inch, and a external dump, adjustable FPR, a vl cat:( 480cc injectors a microtech lt12
pretty much this this motor should be capable of what the injectors can handle yea?
aparently 470hp at the fly, am i being optomisic or just looking for a big BANG!
yep i just referenced it with another fuel injector calulator, ekkk
100% duty cycle is estimated around 270-280 kw @ rubbers
80% duty cycle is estimated around 200kw @ wheels
92% duty is 250kw @ wheels,
meh maybe thats okay, but then again a fpr will draw some more flow out of injectors i was told about 20% more will be gained
so in the same order
100 duty +20% more flow = 540cc = 330kw @ wheels
80 duty +20% more flow = 540cc = 250kw @ wheels
92duty +20% more flow = 540cc = 300kw @ wheels
what do u think
Oh lol for shits and giggles and the myth that they ARE 480cc plus a fpr for 20% more flow being 576cc it will be 360kw @ wheels at 100% duty
thats a tad less than 500hp at the wheels WOW
Edited by ragex
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
