Hey guys i have a complete and running rb20det silvertop for sale!!
Package comes with:
Complete Rb20det including good condition turbo(minus ancillaries)
Rb20det ECU
Rb20det AFM
Reason For Selling: Upgrading to an RB26/30dett
History: I have only owned this motor for no more then 5-6months, bought it off a fellow car enthusiast.... unsure of k's before i owned but since i have owned it only been driven in and out my driveway and to my work twice which is like no more then 5k's away. Reason for hardly been driven is loss of license, so id thought id build a crazy rb26/30 while imwaiting to get it back so need to sell this!
Doesn't come with wiring loom, but can chuck in other rb parts as spares for some extra $$$
Motor is still in my ceffy will pull out upon a deposit being made!
Price $1000 pretty firm on price.... but all reasonable offers taken into consideration
Contact: PM me or fone me 0402049180
As i have no license i can not deliver the motor so i prefer cash on pickup.
Edited by Mayo
https://www.sau.com.au/forums/topic/175350-rb20det-complete-motor-silvertop/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
