hi guys, well, as per topic, i lost my motorbike keys. its a kawasaki gpx250 - yes im on my L's.
anyone know what would be the cheapest way to get my motorcycle running again! thanks
Pull your ignition out and bring it to a locksmith. Does it also have helmet lock on it as well? did it work off the same key?
Lol
I did the same on my old ZZR250!!!
There is a number on the face of the lock barrel, I think that it is a leter and four numbers.
I took the barrel out and took it in, to find out that this number is a key ID.....
Take the number to a good locksmith and see how you go before pulling it a part.
Try that, You might need proof of owner ship but.....
thanks for the quick replies guys!
4admrn : I rang around and they are trying to charge me around $300!
KeyMaker: It has a helmet lock and a seat lock, all use the same key, any tips on pulling the ignition barrel out? Im a bit nervous, and dont want to screw anything up
seeyagtr: i looked for a number, all i could see was 238-M69 could this be the right number? or do i have to pull out the ignition barrel to find the number? also how much did it cost you to get another one?
thanks heaps guys, i really appreciate your help! i'm getting pissed of with catching the train to the city with all the other plebs every morning :thumbsup:
thanks heaps guys, i really appreciate your help! i'm getting pissed of with catching the train to the city with all the other plebs every morning ;)
No that number you have isn't the one. You should be able to find it stamped on the side of the ignition housing, which involves taking the whole ignition housing and electrical switch off the bike, the electrical switch should be attached to it.
You may find the number on the side of the helmet lock body....maybe, maybe not. Taking the ignition assembly out should just be a matter of screws and bolts and taking off whatever shrouds you have to.
Find whatever numbers you can and pm them to me, I'll tell you if its the right one.
It should cost $30-$50 at the most to get a couple of keys cut from the number, thats if you go to them.
Edited by KeyMaker
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
