hehehe... thats an awesome first attempt though :D getting the 60fts down is the hardest thing i reckon! i usually range from 1.8 (best run) to 2.2... i dread going back out there cause i'll be back to square 1 :D
i do want to know 2rismos technique :D all i remember doing it slipping the clutch a lil then all hell breaks loose! lol!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240171
  • Replies 157
Lolz i was in ONE of the 3-4 of the White R33 Gts25t that night with GTR32 rims up front and 300zx (z32) rims on the rear and the BIG white HKS sticker across the windscreen.
you should of done the burnout, still helps on street rubber just no need to do a monster SMOKEY one. (cough) but seems to work for Moanie on her street rubber(cough) sub 2.0 60ft on 225 federals ey.
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240230
lol!!! for me its not so much the warm tyres as its for the smoke show.. think after all the stalls and bad attempts, i revel in the fact that i can do a semi decent one :laugh:
I miss my sig :domokun: what happened to it :(
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240316
yeah the silver one was mine. i saw a few white 33s there but didnt get the chance to talk. which car were you in?
it makes a bit over 250kw on the dyno so i was expecting much better times. obviously something wrong with my technique.
tyres are bridgestone s03n 255/17 at the rear. i lowered them to 24psi but did not do any burnouts been told they(burnouts) are ineffective with street tyres.
ive tried a normal take off which was my second run, launched with 2500rpm (as what Ben told me to try) it bogged down intially then as soon as it hits 4000-4500rpm (full boost) wheel spin began again until second gear :laugh:
rubbish.smoke thosse tyres up.the tracks coating reacts to a tyre's heat.
i went half a second quicker after i smoked the tyres good.learn how to do a burnout starting in 2nd gear.it wont break anything.just dont go dumping it like you would in 1st gear.prolong the burnout.
you should be able to get much better grip off the line.but another thing.dont just dump it.
if you have a dyno sheet have a look at where the torque of the engine kicks in and or when boost starts to ramp on hard.launch just below that so at least the car is in motion when your power really starts to kick in and you should feel it give you a harder shove in the seat than you have previously experienced because your not wheelspining your tyres are gripping.hopefully :domokun:
and if you can get you head arround to slipping the clutch and feeding the acc on the launch to reduce wheelspin thatd be the way to go also.you will find less wheelspin and faster times.
and get quick as u can.smooth gear changes.
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3240453
Assume most of you guys are using drag radials? If so, what tyre pressure are you running?
Drop them down to 13-15psi if you're not doing so already. Add in a decent burnout (2nd gear) and launch the car by slipping the clutch from 5000-5500rpm (2rismo assured me I wouldn't break anything by doing this and I'm happy to say I haven't done so yet :D ) and you should see an easy 1.8** 60' time or better.
Takes a bit of practise and I've stuffed it up enough times to know, but when done right, there's nothing stopping you from dropping all the way to 1.6** 60'.
Save a tenth at the 60' mark and you should drop at least 2 tenths off your ET :)
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3244390
GooD luck CHris! remember:
-remove spare tyre+tools/jack
-1/4 tank of fuel
-lower tyre pressure to 20-25psi
-NICE BIG BURNOUT FOR MOANIE!
-DRIVE IT LIKE YOU STOLE IT!<as 2rismo would say>
ooh and skip dinner too for less weight :)
https://www.sau.com.au/forums/topic/175434-wsid-117/page/7/#findComment-3249168
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
