Howdy people.
I no longer have a use for these parts. I was going to do a turbo conversion but the car's gone now. Here's a photbucket link http://s164.photobucket.com/albums/u1/RPDsnooze/. Yes I'll ship around the country, at your expense. Choose carefully as I am not a retail shop and therefore don't refund if it's the wrong colour... I recommend you ask questions and/or come look at the items to decide for yourself. I'm located 5 minutes south of Brisbane CBD.
RB25/20 Turbo wastegate actuator - $25
T28/T3 Genuine Nissan Turbo from RB20DET (R32) - also VGC, original, 70,000kms old. - $99 This turbo is too small for the RB30 motor, if fitted would restrict flow, better suited to something around the 2Litre engine size.
Oil temp gauge (internal, needs to be mounted in cup or flush with dashboard). - $15
2 stage boost switch solenoid. - $25
Set of four original S3 Silhouette center caps from factory alloy wheels. - $25
See pics http://s164.photobucket.com/albums/u1/RPDsnooze/.
PM me or call on 04171 94005 (Rod).
Cheers
Rod
Edited by SNOOZE
im interested in the t28 for 140. im on the gold coast so i can drive up :) ... what boost is the wastegate actuator running at on the r32 t28?, thanx
VL Turbo brass oil drain connector for block. - $15
RB25 crossover pipe with stock blow-off valve. - $45
I'll take them if you still have them, theyre needed for the hybrid conversion. Im in the brissy area, so can pick up.
Sms me if you can, im not on here much. 0422418299
Thanks mate.
Dave.
Does the R33 Turbo have the elbow or actuator? And willing to post?
Hi NathR32
Sorry for the late reply, it's been a crazy weekend.
I am willing to post, and that turbo doesn't have an elbow or actuator.
The smaller turbo has the stock metal elbow tho.
Cheers
Rod
im interested in the t28 for 140. im on the gold coast so i can drive up :D ... what boost is the wastegate actuator running at on the r32 t28?, thanx
Series 2, sounds good, the R32 T28 doesn't have an actuator attached to it, but the separate one I have listed was running at about 12psi.
Let me know of a good time for you and we'll meet up.
Cheers
Rod
your inbox cant receive pm's atm.
the oil and water lines you have are they by any chance one to hook up a r33 tubo to a rb20 r32?
Sorry Mahartika they're sold already.
Updating the listing now.
Cheers
Rod
Thanks mate.
Dave.
No worries Dave, the crossover is yours, you were the first to call.
Cheers
Rod
Cheers
Rod
If it falls through i will take the bov.
sorry to hi-jack ur post but if somebuys ur turbo i have a Rb20 wastegate actuator(10psi) for $40
EDIT: $40
Edited by justain
sorry to hi-jack ur post but if somebuys ur turbo i have a Rb20 wastegate actuator(10psi) for $45 plus post.
lol, thanks for that. :laugh:
I believe the one I'm selling was altered to run around 13psi, from what I've been told anyhow.
Choice is always a good thing tho.
Cheers
Rod
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
