dan.1337 Posted July 9, 2007 Share Posted July 9, 2007 (edited) Since yesterday my idle has been revving from 600rpm to 1000rpm and then dropping back to 600 and doing it all over again. It happens when my engine is warm and at operating temperature. I was told the map sensor is very sensitive and a bad batch of fuel could be affecting the tune, so it is hunting on idle. Would anyone konw what's going on? Thanks! Edited July 9, 2007 by dan.1337 Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/ Share on other sites More sharing options...
1400r Posted July 10, 2007 Share Posted July 10, 2007 search aac valve iaac valve Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221466 Share on other sites More sharing options...
mad082 Posted July 10, 2007 Share Posted July 10, 2007 i'm pretty sure it's iac, not iaac. but yes, those 2 valves are usually responsible for 90% of the problems like this. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221475 Share on other sites More sharing options...
AdamsR33 Posted July 10, 2007 Share Posted July 10, 2007 yeah i had this problem, cleaned my aac and all was good. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221483 Share on other sites More sharing options...
mad082 Posted July 10, 2007 Share Posted July 10, 2007 it can be a bit of a pain to get off. it is situated at the back of the plenum on the drivers side. trying to disconnect the lower hoses is the hard bit. just out of curiosity, has this affected your vacuum vacuum on your boost gauge? is it closer to zero that it used to be? Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221491 Share on other sites More sharing options...
dan.1337 Posted July 10, 2007 Author Share Posted July 10, 2007 THANKS! found the tutorial and will try it very soon =) link for anyone who is curious: http://www.skylinesaustralia.com/forums/in...mp;hl=aac+valve Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221492 Share on other sites More sharing options...
dan.1337 Posted July 10, 2007 Author Share Posted July 10, 2007 would anyone konw if i can use wd40 to clean it instead of carby cleaner? i will take pics for an rb20 when i do it. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221505 Share on other sites More sharing options...
mad082 Posted July 10, 2007 Share Posted July 10, 2007 no. carby cleaner cleans carbon deposits it. wd40 is basically just an oil. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221529 Share on other sites More sharing options...
dan.1337 Posted July 10, 2007 Author Share Posted July 10, 2007 no. carby cleaner cleans carbon deposits it. wd40 is basically just an oil. thanks, will get some of this on my lunchbreak today. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3221540 Share on other sites More sharing options...
dan.1337 Posted July 11, 2007 Author Share Posted July 11, 2007 If anyone is after carby cleaner, Repco has it on special now. I paid $3.80 for a huge can of it. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3223554 Share on other sites More sharing options...
BAMR33 Posted July 11, 2007 Share Posted July 11, 2007 It won't be the iac as this gets progressively worse, not instantly... Check for popped off/cracked hoses, particularly between BOV and manifold. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3224684 Share on other sites More sharing options...
BAMR33 Posted July 11, 2007 Share Posted July 11, 2007 Also motortech carby cleaner is shit, 50 cans of it isn't worth $3.80. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3224687 Share on other sites More sharing options...
cosworth1971 Posted July 12, 2007 Share Posted July 12, 2007 dont u need to adjust the idle with wires disconected from the throttle to 650-850 then turn the cars off plug wires back in and its all calibrated to that? i know if my idle isnt set to the computer it hunts?? usually on TPS cars u need to do this so cold start and warm start work properly Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3225463 Share on other sites More sharing options...
mad082 Posted July 12, 2007 Share Posted July 12, 2007 this is a problem that occurs on cars that haven't had any adjustment done. it will just pop up all of a sudden. then you clean the valve and it goes away. Link to comment https://www.sau.com.au/forums/topic/175949-idle-revving-between-600rpm-to-1000rpm/#findComment-3225489 Share on other sites More sharing options...
