Hey,
Just wondering what pineapples i should get. I am steering away from ebay apples cause they are probbaly just slapped together and not even though of angles etc.
If possible id like to replace factory items too. Ive been told only alloy ones will replace the factory ones too. Id like polyurethane though if possible. Also whats all that jazz about 4 pineapples and then u put in 8 if u wanna drift etc...
I am setting up my car with all the handling components redone with new balljoints etc. and while the cradle is out im going to do pineapples.. What do you recommend?...ebay, uras, g-13 etc..etc..
And the car is street drivin and used for occasional drift.
thanks
https://www.sau.com.au/forums/topic/176330-which-pineapples/
You can buy replacement bushes, like the Noltec ones. The installation process is FAR harder and more time consuming than pineapples of the C-style solid cradle bushes. I dont know of any alloy bushes that replace the stock bushes, only the C-style which is used in conjunction with the stock one to crush it down and become pretty much solid.
I just put in C-style solid cradle bushes in my 180 and the bolts for the rear member are not long enough to accommodate the pineapples (which I bought at the same time) as well, so beware of that.
By the way which would be best to use? The solid cradle bushes or the pineapples? I'm in a competition this week so went with the solid cradle bushes as I though that they wouldn't change too drastically the handling of the car, but will try the pineapples at some stage.
PS. I drift.
well... i am in process of buying a new cradle and i have ordered lower control, camber and hicas lock bar on its way and i am searching for toe arm too. Does anyone have any idea how much noltech bushes are?? sounds like these might do the trick... and how do you "adjust squat" or is it just pineapples change it.. you cant like.. tune them in a sense can you?
Noltec don't do subframe alignment kits, only replacement bushes. PM me for prices.
There are 4 settings for the rear subframe angle using pineaples, but most people only use 3;
1. all round
2. maximum traction
3. drift
The subframe angle changes using pineapples are not drastic, however you can then shim them I you really wanted to fine tune the anti squat geometry. Although that is better done at the lower control arm inner mounting points with eccentric crush tubes.
:rant: cheers :(
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
