Bee R make a rev limiter and launch controller that you can install in cabin.
It basically allows you to set your desired rev limit. Unlike factory rev limiters which cut fuel, this one cuts ignition, so fuel still goes through.
When they hit the hot turbo they ignite and u can get your flames comming out of the exhaust like the movie.
However it will drastically shorten the lifespan of your turbo.
  • Replies 121
Originally posted by Zensoku
but that is what the "ricey arming red missile switch" is for!:bahaha:
Maaaan I had that shit on my strawberry face 180 back in the day as a kill switch for my amp. Back then the only place you could get it was at Jaycar, and it fitted a corresponding PSTN switch... thought I was pioneering shit, until at autosalon my car was right nex to sum otha f00 who had done the same thing... so naturally I had to remove it...
Now every shop carries it. :P
BTW kidd... here's an interview with Lieberman... it belongs to Hiro from Motorex.
http://www.nissanperformancemag.com/march03/lieberman/
NPM: Was the new color scheme strictly chosen for use in the movie "2 Fast 2 Furious" the sequel to "The Fast and the Furious"?
As it will appear in in the upcoming movie "2 Fast 2 Furious"
C.L.: Yes, The car is silver in the movie. It looked awful, so we just got done painting it back to blue. Why anyone would want to put SS Camaro stripes on a JDM Skyline is beyond me, but the guy designing the graphics (Keith Burns, Prod Designer) hates cars and generally needs his head examined when it comes to car accessorization, just my opinion.
NPM: Sounds as though you weren't too happy with their choice and couldn't wait to get it back to the original look afterwards.
C.L.: The gray/blue thing was ok with me. But the aforementioned clueless designer covered my carbon fiber nitrous bottles with chrome vinyl…it was the first thing I changed when I got the car back. In fact, this dude covered every carbon fiber surface with colored vinyl. As you can tell, I'm not very happy about his choices
Hahaha spoken like a tru Skyline owner :P
watched the movie and was also eager to find out what fuel they run. as for those flame thrower kits i had one on my old car and it was the spark plug typr but only ignited the fuel on with the switch was pressed and also caused the ignition to die ( like doing a key banger with out the stress) as for the REAL car comment if you watch a top fuel drag car they have continuos flame for the hole time they drag. aren't they real cars NZM.031
my skyline can pop flames and nearly all the turbo cars i know can pop flames run a different fuel like menthanol or high grade av gas and you'll get more flames
Originally posted by RedLineGTR
the non funny thing would be if someone had it setup like that and one of his mates didnt know imagine if he pressed them...the plenum would go pop..
Yes, I've lost count of the number of plenums I've heard of going 'pop' from nitrous use. Also imagine what would happen when the car finally rolled to a stop.. why at least 500 porcupines would then drag the owner and his friend from the car and beat them senseless. Because as we all know this is what happens when you use too much NOS. Just like parts of the floor falling off really isn't it, you know -- the excess NOS finds it's way to the seam welds and unwelds them.
Zensoku,
You should put little NOS stickers on the horn buttons and charge twice as much for the steering wheels I reckon.
Like it isn't already happening in Sydney and the Gold Coast.. its on all the Wannabe rice boys shopping lists...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
