anyone here had any experiance with painting mag wheels?
i have sparco 17 x 9's and was thinking bout changing them from black/red to matt gold/platinum...
is it expensive?
worth it?
If your a hot4's reader, they did an article on this about a year ago...
Looked fairly easy.... just sand, prime, paint and finish...
(but it all looks easy in a mag)
good luck
https://www.sau.com.au/forums/topic/176577-painting-wheels/#findComment-3229658
good luck
hmmm... probably should have mentioned that i want to pay someone else to do it... :blink:
https://www.sau.com.au/forums/topic/176577-painting-wheels/#findComment-3229709
ive heard that brake dust can get infused with the rims if powder coated...
and if u paint them urself, then wen u get lil' stone chips and stuff they can look a bit dodgy cause the colour beneath will show up.
My mate purchased an s15, and the tards who owned it b4 him painted the 17" BBS wheels black. now the paint is flaking off and they look shit.
id look at powder coating them...and ask about the brake dust issue..
https://www.sau.com.au/forums/topic/176577-painting-wheels/#findComment-3229715
I had 17inch wheels on my commodore that were repainted they turned out just like knew... people make the mistake of getting there wheels painted in acrylic (mind you if plenty of clear coat will work), if done in a 2pac they will last. At bodyworks it would cost about $70 - $80 a rim, but if your experienced you can do it yourself... just remember when using 2pac paint wear a decent respatory mask not a crappy dust mask as it is very very harsh on the lungs.
https://www.sau.com.au/forums/topic/176577-painting-wheels/#findComment-3229735
Get it done properly.
I had my current set of rims done by a smash repairer. They didn't strip them back to bare metal, and so they've flaked pretty badly.
My new set, I got painted properly. Sandblasted back, painted, and baked. They should be nice and durable.
https://www.sau.com.au/forums/topic/176577-painting-wheels/#findComment-3232325
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
