A few months ago i posted my thoughts on buying a NA skyline due to P Plate Laws.
Many people went against this decision saying it takes the fun out of owning a skyline.
well i love it, its still the fastest car i have ever driven (much quicker then mums v6 magna)
and i can say to myself "i own a skyline"
mods are: tinted windows, lowered, After market rims, Exhaust tip to increase sound & nismo front spoiler.
I live in Kew in Melbourne so i will hopefully start to see you all around (im still on my L's)
NA FTW
Edited by finster
https://www.sau.com.au/forums/topic/176600-first-skyline-na-r33-s2/
nice to have you on board Daniel. a nice clean car you go there; loving the avs (i think) rims. they definitely suit the car.
and yes you're right, at the end of the day owning a skyline isn't about owning a "turbo", it's about enjoying a car that looks good, handles better, and goes better than the average car on the street.
use this opportunity to learn the dynamics of the car, get a feel of how it handles, learn to control a rwd vehicle and just simply have fun. having an n/a doesn't mean you're slow, it just means you have to work that much harder to gain those extra few seconds.
any questions you have about your car, i'm sure many of us would be willing to answer them. be sure to search before hand in case your question has been brought up before.
cheers
edit: and while i agree that the search for power is addictive, keep in mind there's more to driving than just outright power; most wouldn't know how to get the most out of their 400rwkw gtst anyway. suspension, braking and driver skill also come into play :blink:
Congratulations mate!
my first car was a 94 R33 GTS. Was a great car and now im upgrading to a turbo. N/As are great for fuel and insurance purposes in comparison to the turbo versions (as stated above). And if i had a turbo for my first car i am positive i would have crashed it. So (as stated above) dont let people talk to you down about it. If turbo drivers give you shit about driving an N/A tell them your replacement parts cost a shitload less then theirs.
sweet ride bro i have a mate who lives around kew so he will definatly see you going around i bought my first skyline approx 5 months ago no and it NA n i love it i have a thread in th eNA section which is still active so cheak it out, anyhow, i had problem with my engine (my own fault) n now i putting the DET in so yeaha the mod bug and the need for speed takes over pretty quick! but welcome to SAU
Hame
thanks everyone. i cant wait to start getting to know everyone during meets & cruises.
h@me - i frequently see a magnificent yellow r33 skyline that parks at the end of sackville street. if this is your mates i am Very Jealous
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
