Hey guys,
I'm selling my TEIN coilovers, they are in very good condition only used for short time in my R33 as car got sold.
and now have no further use for them.
They are in fantastic condition and suit both R33 and R34 4door.
Would like $900 but negotiable as always.
Also have ZCAS japanese performance breakpads. 4 Pads They are brand new in box, suited for R32. $150
Located in adelaide. Local pickup is welcome and am also willing to send interstate.
Cheers
hey mate i am keen on the coil overs, how old are they and can i get the model numbers of the side, fark you had them set low......
hey mate, i only had them in my car for a couple of months.
i'll pm you the model numbers after work tonight.
where are you located?
just out of curiousity how much are you charging for postage to brisbane qld 4301 for the coilovers
i've sent a pair to qld before a while ago and i think i paid $80 registered post
i'll double check though
u say these will go on 4doors but wat about r34 coupes
not quite
the front is exactly the same on the r33 and r34 coupe and sedan
however the rear set is a bit different, the mounts are the same, but the bottom of it is different between the coupes and sedans.
whats the rear look like on yours?
spring rates???
pm me ur best price to brisbane..
not too sure of spring rates, was quite a comfortable ride though.
coupes and sedans have the same suspension setup for GTT. Unless you are comparing NA and turbo then there is a difference. So if yours came off a GTT sedan, it will definately fit a GTT coupe.
i'll post up pics of the difference between coupes and sedans, just so that someone doesnt end up buying it and it doesnt end up fitting.
hope this will take care of the confusion, the standard struts are from an R34 COUPE
the bottom of the strut is different shaped to that of the coilovers, the mounts on the top are exactly the same.
I'm not sure if every R34 coupe is the same though.
Sorry don't mean to spam ur thread, jst want to set the record straight, as I mentioned before, GTT coupe and sedan suspension is exactly the same (front strut has an eye and rears have the fork)
What you have should fit an NA R34 sedan or coupe or a GTV as they are called. They have an eye on the rear strut instead of a fork. I have attached pics of my Teins to suit GTT sedan or coupe. Hope this clears things up and GL with ur sale.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
