Sorry don't mean to spam ur thread, jst want to set the record straight, as I mentioned before, GTT coupe and sedan suspension is exactly the same (front strut has an eye and rears have the fork)
What you have should fit an NA R34 sedan or coupe or a GTV as they are called. They have an eye on the rear strut instead of a fork. I have attached pics of my Teins to suit GTT sedan or coupe. Hope this clears things up and GL with ur sale.
cool thanks,
wasnt too sure which model it would fit.
so anyone want these beauties?? :)
would those pads fit 33 gtst?...i know the brakes are different but not sure how different. maybe same rear pads?...wouldnt mind getting front/rear pair if fitted and u dont mind seperating. cheers
If u can check the spring rates I would be interested in purchasing the springs off you, that is if ur willing to seperate.
i would prefer to sell them complete
sorry mate
Edited by Tommmo
not sure what the difference between the two is,
but once again i would prefer to sell them together
Hmmm interested in those coil overs, let me scrape together some money and then I will contact you - if you have not sold them by then!
In Adelaide too
In Adelaide too
pm sent
hey mate, how certain are u that these will fit a r34 N/A. have u put them in a 34? just wondering cause im looking at getting some.
cheers luke
price is negotiable
Worth a shot..
Meet you a bit over half way on the coilovers.. :pirate: (plus postage)
And will drop the money into your account today..
Cheers Wayne
cheers luke
i'm 100% certain these will fit into an R34 N/A
my friend bought r33 coilovers for his NA R34 thats how i know they fit.
if your still not certain, then just have a look at the photos and compare them to the bottom of your struts, as that is the only difference between them.
cheers
Worth a shot..
Meet you a bit over half way on the coilovers.. :rolleyes: (plus postage)
Cheers Wayne
not quite that negotiable, but was worth a shot :thumbsup:
cheers
just wondering. if i put these in my car, would everything line up. like would the heights been the same each end of the car if i have them on the lowest setting?
cheers luke
cheers luke
i wouldnt keep them on the lowest setting as you would lose your front bar :(
all the heights are even at the moment, so the car will sit quite even
In Adelaide too
have been sold!
enjoy buddy, hope you didnt have too much trouble putting them in :thumbsup:
Free Bump-I got a set if there the flex model there tuff as i got EDFC controller aswell cant go wrong with kantong...easy as 2 adjust and not bumpy @ all :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
