ive got r33 turbo, manifold and dump/front pipe...
ive got full cooler kit
anything ive missed out?
noone wants to buy my cefiro n/a so thought may aswell throw a cheap turbs setup on for the kiddies...
it will only be running 10psi or so... well i dont drive it but for the new owner it should be safe without HG
anything ive missed?
https://www.sau.com.au/forums/topic/176675-rb20det/
wondering how an rb20det a31 ecu is gonna go with the non turbo a31 afm... im kinda trying to do this on a budget
if i was keeping the car i wouldnt bother with this dicking around and id slam a 20det in... but eh... this is easier and cheaper
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3230828
agred it is thats why i not doing the rb25de+t option in my post i doing transplant for rb25det, but yes you need:
Basic run down in price from what i estimate is
- Turbo 200
- Manifold 50
- injectors 100
- Dump 100
- Front pipe 100
- Intercooler 140
- Pipe kit 150
- Oil feed 120
- Emanage 300
- Randoms 100
i have a topic you can read about if you don't like.. http://www.boostcruising.com/forums/index....=209006&hl=
but the ones on SAU are probably better, i prefer them now
GL dude
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231032
You may have to lower compression ratio..
OR..
Go HI COMP TURBO! :) (SOMEONE DO IT ALREADY!)
I dont see why u cant use the A31 ecu.. it will run.. but it may not optimumly..
another thing.. you may need oil feed lines to the turbo from the block..
Id sigguest a retune too.. may need that one..
Have a feeling there is more.. but will dorp back by if i remeber..
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231103
dude, i have a cefiro de+T and i can tell you right now this isn't a "cheap" way to go
you need oil and water feed return lines, plumbing by enzed, DET injectors, colder spark plugs, DET cefiro ECU, cooler piping, new inlet cross pipe, dump, front pipe,
there's heaps you still need, how much are you looking at selling the cefiro for though? i may have an interested friend
seriously though if you're looking at increasing the value of the car then this is not the way to go man, you'll lose a lot of money!
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231162
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
