Hey guys didnt know which section this is best suited. Basically im after plain black throw over seat covers like the axs, slip ons etc. Now cheapest i have found is from axs and they are $69 a pair surely there has to be cheaper somewhere else as they are just plain covers lol. I want a pair for the front and back because i have access to an embroidery machine and im getting a nice logo put on
any idea?
Cheers
Dave
tried fairfield markets, had some but not throw overs, just plain fitted covers. Thats not a bad idea about making my own.
thats really got me thinking. Have you done it?
Ive seen a few at fairfield markets i think?? or maybe it was at trash and treasure?? not to sure but i no ive seen them at one of them places
paddys markets in the city near central station has a small shop in the markets and they sell all types of car accessories. I got my sparco seat covers there for $50 and they also can embroid ur own logo in the covers aswell.This reply probaly wont help you but it might help some1 else.
yeap... seen the place, and is my suggestion too :)
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
