ermmm..
Where can I mount a fire extinguisher? In a R33.
At the moment it's just sitting wobbling in the passenger floor..
Can I just screw into the floor of the passenger floor where the feet are? Wont that like damage the car? :domokun:
Any pictures would be great also!
https://www.sau.com.au/forums/topic/176900-fire-extinguisher/
  • Replies 41
Posted Images
Victor.. these will probably help you:
http://www.skylinesaustralia.com/forums/in...t=0&start=0
http://www.skylinesaustralia.com/forums/in...howtopic=115536
I also got a Supercheapauto fire extinguisher but after some reading and founding out how unreliable they are, i went back to return it and going to buy a BFI Extinguisher.
Cheers Ray!
How much was the BFI one?
I just got a cheap one coz I'll need one for DECA. It is usually $30 but on special for $20 lol.
doodz, put your cheap one in the bin, or give it to your mum to put in the kitchen. what you want is the BFI 1kg extinguisher. It costs $50-$60 and by far out performs any of the cheap ones. Plus I would venture a guess that the $20 you bought has a plastic bracket? If so it is unnaceptable for any CAMS event that requires an extinguisher. Also, you will find most likely it cannot be recharged.
orly?
Yea like that RX7 at EC on that track day.. oh man FIREE!! 2secs later zoom it's all on fire!
hmmmmz Maybe I can return it to supercheap.. hmmmz... or maybe just try it out LOL $20 for thrills :)
Where can you get this BFI one? And which one? Their site has heaps of different ones! :(
BFI Dry Chemical Powder (ABE) Extinguishers
Fireman Dry Chemical Powder (ABE) Extinguishers
Carbon Dioxide (CO2) Extinguishers
Air Water, Air Foam & Wet Chemical Extinguishers
Burnstop Multi-Purpose Extinguishers
Mobile Fire Extinguishers
Mr Fireman Home Protection Package
Marine Fire Extinguishers
Beer Baron: Do you know anyone that has used the CHUBB Fire Extinguishers? they sell them at REPCO for around $30 i think.
Otherwise: i wouldn't mind being in a group buy for BFI fire extinguishers 1kg i've seen them for around $45-$55 delivered off the net.
Brendan if your car is on fire from the rear end(boot area) how do you think you will access the fire extinguisher? Most of the hardcore guys are mounting them under the driver/passenger seat so pretty much under your legs you have to be able to reach it from the drivers side( cams requirement i thinks)
well for cams events it must be able to be reached by the driver WITH seatbelt or harness on. so either under drivers seat, or passenger seat, or somewhere around the centre console is pretty much the only place.
I haven't used the chubb ones but they have a pretty good rep.
the BFI ones are good. I've used them and I've used some other lame-o ones (can't remember brand) and they were rubbish.
doodz, the one you want is BFI Dry Chemical Powder (ABE) Extinguishers.
This is it: http://www.firstaidsales.com.au/component/...emart/Itemid,1/
compare it's rating to the one you have. the BFI 1kg one is 1A,20B:E and again you must have an all metal bracket (the BFI one comes with it).
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
