hey guys,
just wondering if someone could tell me if a set of 19 x 8.5 would go on a standard 33 gts-t thats not dropped at all without rubbing or hitting the calipers.
i was talking about this topic with a friend, he has a set of 17 x 9 and he has guard rubbing when he full locks the steering. its not noticable when just driving in a straight line or if hes not full lock on the streering. he's cars been lowered 2.5", so just doing the math.. i assume, the 19" would fit my car?
putting the rims on the car at the moment isn't a posibility either..
any input would help heaps!!
-G
https://www.sau.com.au/forums/topic/176951-19-x-85-on-stock-skyline-33/
You wouldn't know whether a wheel would fit or not until you actually try them on. All wheels have a different spoke design. Just say you were given two wheels with the same specs (offset, width, etc.), but different spoke design, one could fit and the other might not. You wouldn't know whether the wheel will fit unless you try them on or someone has had experienced with them.
Also to make it easier for someone to determine whether a wheel will fit or not, you need to give us an offset for the wheels you're talking about.
Cheers
Cheers
yup, i get ya. thanx..
i'v tried the rim on the car as a matter of fact, the thing is, i didnt move the rim about on the studs at all. it had a fair bit of clearnace, and i was hoping i could get an answer, but obviously not.. thanx for the input bud.
-G
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
