Brand New D2r Hid Globes, Direct Drop-in For R34's With Factory Hid, 2 X 6000k And 1 X 8000k
As the title says, these are brand new drop-in replacements for those highly expensive HID D2R factory globes.
Can be replaced in minutes, I've got
2 x 6000K sets (very white)
1 x 8000K set (slight blue hue) SOLD
$75 for a set (2 globes) delivered express throughout Australia.
Hey Dan, how do these compare with the stock HID's? (The 6000k ones)
And would it match the color of your LED's?
Edited by Fujiwara
They're very close in colour to the LEDs actually, I always think (being fussy) the stock HID are slightly less blue than the LEDs. This could be due to age of my factory ones though. Also the new bulbs have a slight colour shif after 500 hours and get a bit white-bluer.
Got decent white (but not noticeably illegal) replacements for halogens? Bastards at compliance never returned my Xenons...
Sorry no halogens, only HID
whats the kelvin rating on the stock HID's?
And can the wiring/loom handle 8000k
8000K refers to the colour temperature, they don't use any more current load than the stock globes, these are 35W just the same.
I've heard figures of 4200-4700K for stock...I'm tending toward the 4700K
i got 2 sets of dan awsome xennon bulbs .. huge diff over stock 4200k xennons.. thanks a bunch bud for them :banana: well worth the money
P.S my fatory booklet states mine was a 4200K maybe the earlier ones were different??.. 8000K is worth it :yes:
Edited by 53XYN
does the 8000k still light up as much or more as the standard ones?
I haven't done the 6000K side by side with the 8000K, but it was brighter than the stock ones, just with a bluer tinge to it. My stock ones are older though and probably getting toward the end of their useful life.
Dan just letting you know i found my steaga S2 lights they use D2R as well your 8000K ones fit in Steaga perfectly exact same setup as 34
S2 Steaga are Xennon Series one stock H4 or H1..
Edited by 53XYN
I used a stock loom for 9000k with no problem at all.. :cool:
i tried to take out my globes today and found out that there is a star shaped allen like key thing there.
WHERE THE HELL DO I GET ONE AND WHAT SIZE IS IT!!!???
Can any of you guys help me? As i'm getting a set off dan.
Cheers
Cheers
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :D
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :P
i don't want to be doing that.
knowing me, i'd break alot of things
You turn the cover with one hand, keeping pressure on it, flip the plastic tab with your finger slightly and it'll jump over the screw. When you do it up, just don't force it past when you screw the cover back.
Hey ,mate.
Just sent the payment through.
Please send me a set of 6000k globes.
Also which way do i turn the covers and how much do i turn them to take it off?
Is there no place that sell the star shaped allen keys? :laugh:
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
