  • 4 weeks later...
looks nice, but im on my P's and the rule:
a high powered vehicle is considered to be any vehicle with a power to weight ratio over 125 kw per tonne, or with an engine capacity to weight ratio over 3.5 litres per tonne. This includes any make of car. (from: http://www.arrivealive.vic.gov.au/c_youngGLS_9b.html)
would your car be legal for me to drive?
thanks
https://www.sau.com.au/forums/topic/177700-sold/#findComment-3375677
No idea man.
I havent really got the time for that sort of stuff
Only way I would sell interstate is if the money was in my account and all I had to do was drive it somewhere and leave it for a freight company
https://www.sau.com.au/forums/topic/177700-sold/#findComment-3378188
No idea. Havent got the time to find out sorry
If interstate buyers are interested then all arrangesments would need to be made by them. All ide want to do is drive it somewhere, sign some paper and go home.
https://www.sau.com.au/forums/topic/177700-sold/#findComment-3396313
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
