Hi all
I need help so if anyone can give few words advice I will be glad...
So i have R33 RB25DET, just have modified and installed FMIC catback 3" and intake, so i just bought turbo for my car and have instaled on it, it has internal westgate 11 PSi, but have problem when am runing on slowly it has no problem but when going agrecive acceleration in peak it has detonation, please advise somthing or what processes i should provide when goint to install aftermarket turbo, and yed i have stock fuel pump and injectors, just nothing change on this car just FMIC, catback and intake....
and yes sparks seems like never changed on this car i checked and looks like thay are ok... do i need change them anyway?
please help because my car is much slower than before now:(, and here we dont have any dynos:(
P>S and yes i think turbo is ok and dont have any problem because its shows 10-11PSI on peak but begining detonation..
HELP HELP HELP
thanks in advanced
Edited by guricha
https://www.sau.com.au/forums/topic/177867-detonation/
I assume your running an aftermarket turbo on the standard ecu. That is your problem.
do you thinks so? what should i do? and i know some guys and thay have stock ECU but runing on 13 PSI but its ok..
https://www.sau.com.au/forums/topic/177867-detonation/#findComment-3246816
Yes, but thats the stock turbo.
Just because one car "seems" fine, doesnt mean the next one will be :thumbsup:
If you have detonation its generally
*The tune is crap (in your case, its not even better than factory which is a major issue)
*Injectors not upto the task
*Fuel pump, could be on its way out
Although, having changed the turbo. I dont know why you wouldnt have installed a dump pipe aswell, thats another key mod
https://www.sau.com.au/forums/topic/177867-detonation/#findComment-3247198
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
