What a load of shit!
How does the US dollar effect the price of cars that are already in the country?
Actually how does it effect the price of cars coming from Japan either?
If anything, a strong $AU makes things cheaper from overseas.
Back on topic :)
I felt I got a reasonable price and a pretty quick sale.
It results in pushing the current ASP's (Average selling price) down on anything imported.
Its killing the technoligy industry at the moment as grey imports are 1/2 the price of the retail stores.
Which may sound good now, but wholesalers will compensate by jacking up profit margins now and once the dollar drops again the ASP's will rise again to higher prices that before the wave started. In short its good right now, but will be bad round xmas time when most people spend a packet. My advice shop for xmas now...
IE. 50" High def plazma from Sony (Bravia X series) in China $2200AUD, in Australia $4800AUD (quoting cheapest prices seen).
Even if you pay through the teeth on shipping its still going to be a grand less than is sells for in Australia.
Thats the problem with a astong dollar... :)
Stronger $AU means cheaper importation which means cheaper prices on resale from both the However, the primary problem with import resale is basic supply and demand.
Its always about supply and demand, everything in this world is about supply and demand... :)
yeah,I suppose that makes sense,
sorry COL!!!
You better be, no one understands world economic pressures on the depressed seal cubs in antartica like me :)
congrats with the sale mud, didnt take long after u put the ads around
ive finally got all my cash together and looking around for anything with lowish ks (preferably series 2) if anyone sees any around
adam
adam
Yeah it was suprisingly quick.
I thought that thing would be harder to shake than herpes.
Talk to COL-GTSX he's looking to sell and it is an immaculate car.
  • 1 year later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
