that'l cost him an arm and a leg
electric thermo?
Is it better to spend all your time chasing and changing cheap parts or spending a little bit more and know that it's right and will be right for a long time. It would work out cheaper in the long run I would have thought. Or maybe it's just me.
Edited by Wogboy
It was broken, I crashed... smashed the standard one to pieces... Thought I'd do the smart thing and replace with better gear when I was fixing it, then gradually returned everything back to stock until it stopped over heating... Now it's ideal again so no dramas at all..
