Okay a little bit of background.
Driveline is a RB25DET stock internals, dual stage boost controller, HKS Pod, 3" Exhaust, PowerFC, Bosch 040 and 10 PSI.
We just finished installing a gready plenum on his car to get rid of that nasty pipe work, also installed a Q45 throttle body at the same time.
Car was running perfectly before hand, now when it starts up, first rev is fine and for about 3 seconds it runs fine then all of a sudden it starts misfiring. Only problem is that the misfiring sounds random and not like its consistantly coming from one (or more) cylinders.
Little bit of white smoke is coming out the exhaust but thats nothing unusual, probably just condensation from a cold start.
I pulled the manifold off, checked the head (its straight) checked the plenum (its straight) bolted it back up. Also when i disconnect the AAC connections that i had to lengthen to connect under the plenum it makes no difference to the engines behaviour.
Also the longer i leave it running the worse the misfiring becomes... Is there anything i can check on the hand controller to narrow down the problem?
Could anyone suggest something i should try to fix this, i dont think its coils, plugs etc coz it was working fine before hand, must be something to do with the plenum/throttle body upgrade.
Your input is appreciated :)
Edited by hecticrb25
https://www.sau.com.au/forums/topic/178181-misfiring/
PowerFC only needs to be changed if you use a Q45 AFM. We do have a Q45 afm to bolt up to it but i want to get this issue sorted before doing more upgrades. I bolted the TPS from the stock throttle body on the Q45 (it came off a S1 and they are the same). Yeah its mist.... i think :)
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252061
ah my bad, misread the post, thought you'd put a q45 afm on, ok, have car idling, disconnect coil pack on cyl 1 via plug, see if engine rpm drop, connect n go through to varify which cylinder has the miss, if its consistent through them all then its not a coil/ignition mis....
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252068
Tried that, made no difference.
Just noticed there is a small water leak coming from under the plenum somewhere :)
Checked the old plenum and its not straight.... however the head is straight?!
You think the head will have to come off and be machined?
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252079
Well when i disconnected the coils it did sound like it was missing more (obviously as i just disconnected a cylinder) however it still missed randomly.
I used a straight edge and placed it on a few different angles on the head.
Probably water getting into the cylinder from a leak yeah?
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252106
ok u need to do it to all the cylinder one by one, to varify which sylinder is being affected, could be that u have an air leak at the gasket n its making a particular cylinder or two run lean, squirting water down onto top side or plenum flange where it meets head while engine is running is another way to check for air leaks, engine will miss more if water is being sucked it to engine....
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252114
yeah but there no reason for water to be flowing from somewhere into your intake chamber, not really possible with the greddy plenum unless theres a casting fault.... yeah check engine oil on dipstick i guess, not likely though, check for vacuum leak also, simple things can be overlooked, line for boost gauge/fuel reg/bov etc
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252138
anyway im off man but try squirting water using a squirter bottle onto the top of the flange plate where the greddy plenum nmeets your head when car is running, make sure u put water back in the engine too :) dont want it getting hot on u.... you'll know if you hit the area with the air leak as engine revs will play up... good luck
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252147
Lets say the water/air leak is coming from the plenum\head connection and not the boost guage\brake booster\fuel pressure regulator\pcv valve\pollution gear lines.
What would the solution be? Seeing as the faces look flat..... new gasket is all i can think of :)
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3252160
Hey guys.
Found the water leak, water inlet pipe to the plenum from the radiator had a minor crack that was causing that issue.
Now just to find the air leak and all should be fine :huh:
BTW the throttle cable mount from the standard plenum isnt the correct one for the greddy plenum, what has everyone else used instead?
Cheers!
https://www.sau.com.au/forums/topic/178181-misfiring/#findComment-3263079
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
