The GTR's guards and bonnet are also much lighter than the GTSt gear.
you need to do the grill bonnet and guards bud, all at once
You don't need to change the grille, bonnet and gaurds at once. You can change the bonnet and keep the 'normal' gaurds. If you change the gaurds, chances are, you'll need a new front bar.
if you change the bonnet you WILL need to change the grill ...
Bonnet is different (and the GTR one is alloy)
Guard are different (and the GTR ones are alloy)
Grill is different (GTST has no grill)
Latch is different
Front bumper is different
basically nothing is the same.
Latch is different
all in all, you gotta love skylines......
they look similar, yet are so different when ya get down to the fine details.
lol
mate, gd luck with the what ever your doing
(i cant say any thing new/else as its been stated prior)
Edited by SEX-DR.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
