New globes and aimed up slightly. Light up the road better than a VN dunga door and don't look out of the ordinary when driving in the opposite direction (I had the other half drive the line and I drove the vn dunga door)
I had a crash shop set mine up; they had a wall with markings painted on it. The way they setup mine up they were basically pointing at the road directly in front.
i have the same lights, one was sharp one was dull - two brand new globes i think they were $25 each and bob was my uncle. awesome lighting
ha ha although those spotties that i have would have lit up the road heaps well. lol. jks
hmmm cant fit spottys when theres a 600x300x78 core size fmic in the way. spwenin
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
