Drift King drives both the Amuse Supra and Mines R34 GTR. this is an oldie, but a goodie.... i love the comments they make right at the end. "Accelerate's as fast as the GT500 cars...". just awesome....
http://www.youtube.com/watch?v=f8yy65oIths
  • Replies 168
Prank call the telemarketer...
http://www.youtube.com/watch?v=J5z4Vs26-TI
I usually just tell them that "now isn't a good time for me" and ask them for their home number so I can call them backat a time thats convenient... and when they say "I can't give you my home number, thats private" to which I respond with "WELL THEN WTF MAKES YOU THINK MINE ISN'T????"
They don't like that much :D
Edited by LadyBytes
I am sorry but this takes the cake for just out right AWwwwwwwwww factor he did pull off a sweet 720 but just watch what happens then.
JAKE BROWN + X GAMES + BIG RAMP = AWWWWWWWWwwwwwwwwwwwwwww
and another view with more comments AWwwwwww
http://www.youtube.com/watch?v=sOKhe9k4eg4
Dont know how to describe this one other than a Swedish boy deliberately jumps into a wall in the most hilarious possible position (bar a nut shot), just keep looping the body slam, gets funnier every time
http://my.break.com/media/view.aspx?ContentID=350207
haha!
changing the theme completly now...! i love this commercial. i wish we got it here.... turn up the volume and enjoy!
http://www.youtube.com/watch?v=7qT_q8PXFrw
the bridge at the 50 second mark is Sea Cliff bridge down at Stanwell
Smack in the middle of the city of Munich is a permanent wave that people surf on all year round
Once you are there you will see better surfing ones for the same place, but this vid gives you an idea of what we mean by "smack in the middle of Munich"
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
