Hey guys,
Just got back to Cairns, keen to do a cruise with who ever is keen. Normally go up the kuranda range, via mareeba, stop at mt molloy for a burger, down the julatten range, then cap cook highway. Normally takes the good part of a day but some decent roads. Not sure when, I'm up for another 3 weeks just thought i'd suss out who was keen.
I'm up in Cairns - sorry, with a hire car after a plane flight - on the Easter weekend.
Up to see some rellies.
But I will take note of that route of yours jnb, and try it out.
The hire car will make me go like a granny!
  • Replies 100
Guys need some ideas on where to go for a tune...? Spent wayy to much money on my car lately and the final step is the tune. She'll be running great after that. Anyone have any opinions on decent places to go?
  • 3 weeks later...
  • 4 weeks later...
Im wanting to sell my turbo.
It is an HKS 2535. A bit more power over standard with very similar boost response.
Direct bolt on to R32 and R33 , im pretty sure it will fit R34 aswell.
Its still attached to my car, so I can take you for a spin to see what its like.
As comparison, a stock R33 will make about 130kw atw, and R34 GTT stock will make about the 150kw mark.
The turbo on my car makes 180kw atw on only 10psi.
Nothing wrong with the turbo, just chasing more power now.
Be warned however, with stock injectors you will be able to run only about 10-12psi.
Possibly even maxing out your AFM.
I can help fit the turbo on to your car aswell, and change injectors if you have them.
$1000 for SAU
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
Hey guys, any opinions on tuners in the Cairns area?
Cheers
  • 2 months later...
Cheers
I'm after the same info. I hear SVS is good but expensive.
I've got an R32 GTR.
Just bought a truck load of parts from Japan. HKS GTSS turbo's, Tomei Poncams, HKS dumps, front pipe, cat, cat back, and a few other goodies. I'm just waiting for a Power FC and a Tomei manifold and I want to get all of this bolted on and tuned.
Anyone dealt with SVS or know any other decent tuners in Cairns?
I do my own tuning, but when I need dyno time, Cameron at SVS is the gun tuner for skylines up here.
The other place up here with an AWD dyno dropped a friends EVO8 off the side a little over a year ago, and then tried to repair the damage on the cheap. (exhaust and tank damage)
Other offerings are single roller dynos. I've heard neither good or bad reports about their capabilities though. Its really hard to trust people's opinions up here too. Seems 1/2 the people in the car scene up here are full of a mix of dreams, second hand information and BS.
Cheers Ian,
Thanks for the info.
That EVO8 horror story is my worst nightmare. I hear you about the car scene in Cairns. I'm just after a responsive, reliable GTR. Not chasing big dyno numbers like most other people these days.
Are there ever any meets up here? Seems pretty quiet.
Edited by GOJ1RA
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
