Hey guys,
Just got back to Cairns, keen to do a cruise with who ever is keen. Normally go up the kuranda range, via mareeba, stop at mt molloy for a burger, down the julatten range, then cap cook highway. Normally takes the good part of a day but some decent roads. Not sure when, I'm up for another 3 weeks just thought i'd suss out who was keen.
I'm up in Cairns - sorry, with a hire car after a plane flight - on the Easter weekend.
Up to see some rellies.
But I will take note of that route of yours jnb, and try it out.
The hire car will make me go like a granny!
  • Replies 100
Guys need some ideas on where to go for a tune...? Spent wayy to much money on my car lately and the final step is the tune. She'll be running great after that. Anyone have any opinions on decent places to go?
  • 3 weeks later...
  • 4 weeks later...
Im wanting to sell my turbo.
It is an HKS 2535. A bit more power over standard with very similar boost response.
Direct bolt on to R32 and R33 , im pretty sure it will fit R34 aswell.
Its still attached to my car, so I can take you for a spin to see what its like.
As comparison, a stock R33 will make about 130kw atw, and R34 GTT stock will make about the 150kw mark.
The turbo on my car makes 180kw atw on only 10psi.
Nothing wrong with the turbo, just chasing more power now.
Be warned however, with stock injectors you will be able to run only about 10-12psi.
Possibly even maxing out your AFM.
I can help fit the turbo on to your car aswell, and change injectors if you have them.
$1000 for SAU
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
Hey guys, any opinions on tuners in the Cairns area?
Cheers
  • 2 months later...
Cheers
I'm after the same info. I hear SVS is good but expensive.
I've got an R32 GTR.
Just bought a truck load of parts from Japan. HKS GTSS turbo's, Tomei Poncams, HKS dumps, front pipe, cat, cat back, and a few other goodies. I'm just waiting for a Power FC and a Tomei manifold and I want to get all of this bolted on and tuned.
Anyone dealt with SVS or know any other decent tuners in Cairns?
I do my own tuning, but when I need dyno time, Cameron at SVS is the gun tuner for skylines up here.
The other place up here with an AWD dyno dropped a friends EVO8 off the side a little over a year ago, and then tried to repair the damage on the cheap. (exhaust and tank damage)
Other offerings are single roller dynos. I've heard neither good or bad reports about their capabilities though. Its really hard to trust people's opinions up here too. Seems 1/2 the people in the car scene up here are full of a mix of dreams, second hand information and BS.
Cheers Ian,
Thanks for the info.
That EVO8 horror story is my worst nightmare. I hear you about the car scene in Cairns. I'm just after a responsive, reliable GTR. Not chasing big dyno numbers like most other people these days.
Are there ever any meets up here? Seems pretty quiet.
Edited by GOJ1RA
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
