Ok my 2001 Tommy Kaira R34 GTR is for sale. This car have everything done to it and has been extensively modified by Tommy Kaira in Japan. Way way to must to list but car can be previewed on carslaes.com or call me for more details. Mods including 2.7L stroker, fully built engine including pistons, rods and cams custom N1 turbos Tommy Kaira exhaust, Tommy Kaira signature 19" wheels ARC radiator with built-in oil cooler, Nismo 320kms speedo, Nismo inboard upgraded display screen, Nismo carbon adjustable rear wing, Nismo carbon A-pillars, Nismo side skirts, Nismo carbon intercooler surrounding, Nismo engine mounts and gearbox mount. Makes 330kw@all fours at 1.3BAR though HKS EVC. Unbelievable car with absoutley everything done to this machine. MRC Castle Hill maintains the car.
Very reasonable price at $82k. Please no time wasters and please no offering stupid prices.
Wasim-0410781929
Edited by GTR32X
https://www.sau.com.au/forums/topic/179286-r34-gtr/
  • Replies 51
Posted Images
Thanks alot mate.
Ur welcome... Honestly guys there isnt a word that can explain this car it is so neat and it has got the goods.... and id say the price is well worth it.. id be suprised if you can find a car like this for the money he is asking...
free bump..
https://www.sau.com.au/forums/topic/179286-r34-gtr/#findComment-3270170
free bump..
bump
https://www.sau.com.au/forums/topic/179286-r34-gtr/#findComment-3272249
Awesome car, Best value by far.
Stockers are from 50K-70K. Would love to buy it, but need the cash in other things.
Good luck with the sale.
Thanks alot. alot car for little money
https://www.sau.com.au/forums/topic/179286-r34-gtr/#findComment-3276547
Wasim is a very good friend of mine.. if this car is not sold by December i will be buying it off him.. i Am 15k Short. Would anybody like to sponsor me ??
hahahah thanks Moey. It would be funny if someone did sponsor u! lol How u been anyways champ
https://www.sau.com.au/forums/topic/179286-r34-gtr/#findComment-3335888
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
