was taking a break from my non existing study and saw on the news that the Yen is now 78.85 aussie cents. how goods that! i bought my car a few months ago and it was around 70. it doesnt seem like much but when your paying decent money it is a big difference.
Example: AUD 20k
@70: 1.4 mil yen
@78.85: 1.577 mil yen
thats an extra 177,000 yen for nothing. Not bad!
https://www.sau.com.au/forums/topic/17933-yen-is-7885-cents/
Originally posted by hippy
i have troubles like that on my gfs computer ..i log in and someone elses name comes up ..
haha exact same thing happens for me, except i cant post under their name, but it shows im logged in as them.
https://www.sau.com.au/forums/topic/17933-yen-is-7885-cents/#findComment-374203
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
