For sale: 1992 Mazda Eunos Cosmo, 13B Twin Turbo.
Item Condition: Good Condition, Used as a daily driver for the past six to eight months.
Price and price conditions: $12,500 NEG
Extra Info: 20 Inch Wheels, Only Mod - K&N Pod Filter, TV, DVD, Custom Audio, Just serviced with; plugs, leads, oil, auto box, radiator flush, brake flush (flat mate is a mechanic by trade).
Wishing to payout my personal loan and buy a cheap hatch back cash!
Pictures @ http://www.dmrh.com.au/2737.htm
Contact Details: Aaron - 0434 281 045 - [email protected]
Delivery & Conditions of Delivery: Pick up only.
Edited by AzZa13Btt
13B?
Yep - they come in 13BTT and 20BTT configurations.
A bloke I know has a 13B bridgeport with a T51R on it - Runs 10s (that's true by the way)
That has to be one of the quicker cosmo's around, 13b's have great potential, as much as the depth of your pockets really hahaha!
Bman, we run into each other on too many forums haha.
Mate,
When was the engine re built and how many kms are on the car. Also how much rego does it have.
Cheers
Engine rebuilt Rick Shaw 2003 @ 115,000km's
Km's sit at 148,XXX.
Rego is March/April 2008.
Mate,
Cheers
hi mate.
wonderin if you would be interested in an r32 gtr + $
http://www.skylinesaustralia.com/forums/in...p;#entry3344909
chers. and good luck :)
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
