hi I have a pair of 32 GTR standard rims, tyres are worn out... pretty good nick only slight gutter rash,
$175 ono
Located on the Sunshine Coast Qld
0406016651 please or PM if you have to :P
thanks
Craig
https://www.sau.com.au/forums/topic/179624-pair-of-standard-r32-gtr-rims/
