  • Replies 64
Posted Images
rear discs, calipers with mount bolts and hoses if they have them, drum shoes and what they mount to.. basically after the full rear brake setup :(? how much with freight to 7018?
cheers, Kent
price check:
windscreen water bottle
fuse box cover
plastic arm rest piece with window controls on drivers door
radiator fan shroud
top right side rubber mount for radiator
how much for the rear end reo bar? are you in melbourne? if so which suburb.
Thanks mate
Edited by sillylankan
  • 3 weeks later...
