Sorry for my incompitence (sp?)
Will this fit a stock RB20/VG30/RB25 turbo? And also will the flange to join the CAT fit the stock cat?
Or is an aftermarket CAT needed?
Cheers,
Brenton
Yes it fits the std turbo, and bolts up to the std cat converter.
  • 3 weeks later...
  • 3 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
