Interesting,
Didn't think this topic would surface again.
I had the too many points in my charts before ^^60 not ^^6F, there are only 16 points not 32 thus the rpm scale is in 400 rpm increments.
The divide by 10 to convert to dwell % was gleened for some ecu tuning forum somewhere.
This appears not to be the case thankfully as 25.5% seemed to be max dwell duty % before.
so i guess i need to work out the constant to convert from ecu values in dec to dwell duty %.
will post back later.
  • 2 years later...
Bump.
I know this thread is old, but I'm going to be doing an LS2 coil swap in favour of the garbage RB20 coils I'm running on my RB30.
Can anyone explain the correlation between dwell duty cycle and actual dwell time so i can set them up properly?
Bump.
They are 2 different things. If frequency didn't change then there would a correlation between the 2 but because frequency increases (with RPM), then duty cycle must increase to achieve the same ON time (in milliseconds) in order to reach coil saturation.
The pic shows that duty cycle has to increase as rpm increases, simply because we have less time.
Ah ok... Makes sense. Do you know if i can even adjust actuall dwell to suit other coils then with nistune?
That pic i posted was from nistune. You can adjust it, but if you add too much duty cycle you will just burn out coils.
Millisecond adjustments with nistune are simply to compensate for lower battery voltages. Duty cycle adjustments are for the on time, which will increase as rpm rises.
Easiest way to find out what is required is to hook coil up to a scope, you will see when full saturation is acheived because current will stop climbing and level out.
Otherwise, provided the primary winding are resistances are massively dissimilar, i would just leave them.
Edited by kjb_r33
Thanks a lot man you've been super helpful. The thing is, I'm going from R32 coils to LS2 coils which have a WAY higher spark energy and a significantly different dwell time (I think), I guess I'll just play with it slowly. Heres some interesting data on the coils I'm using: http://www.megamanual.com/seq/coils.htm
Do you know what the "nominal dwell" would be on the stock coils?
Edited by ST240
It actually states on there to use no more than 6 milliseconds. It also states that the millisecond compensation is for dropping battery voltages. (both can be adjusted with nistune).
Id be inclined to get them wired up, then adjust the dwell duty cycle to achieve the 6ms.
This will give you max coil output at a duty cycle thats not going to shorten coil life excessively.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
