okay since ive sold the onevia and now got a r32 skyline 4 door ;),
all my 4 stud & s13/180sx stufff has to go!!!!!!!
prices are firm unless stated otherwise..
item1got a pair of 4x114.3 bronze koya drift teks in 17x8 +34
offset.
comes with 225/45 tyres 1 side 50% the other 20% or so.
price update $550 with tyres take it as it is these cost me $565 + delivery from adelaide under a year ago :D
more pics upon request guys,
item2 25mm HUBCENTRIC bolt on spacers 4x114.3
only problem with these spacers is that the bolts on the hub are mx1.5(i think) and not mx1.25 like nissans.
correct nuts will be supplied tho so it doesn't matter :worship:
after $90 for the pair pick up in syd.
item3 S14 SR20DET fuel pump (take off a 95 model ADM 200sx) roughly 85XXXkm
after $20 good upgrades for you NA and CA boys..
item4 S13/180sx rear hubs x 2 (left & right) with good bearings. bought off liz from the forums.
was originally for my 180sx which had a suspected rear bearing problem but never got a chance to fit them.
after $30 the pair pick up in syd.
item5 s13 sr20de na standard extractors with o2 sensor.
after $20 pick up in syd.
item6 also got STOCK S13/180sx catback exhaust, good to clear them defects $60 :teehee:
item7 180sx sr20det front brake setup consisting of rotors,calipers & pads.
after $80 pick up in syd
item8 ISC front coilovers to suit s13/180sx used for 5000KM, sold the car so NLR. $400 pick up or extra for delivery
gonna have r32 gtst stockies for sale in a few months time.. may swap for a nice set of dished rims + cash of course..
photo's will be up soon or upon request
all items can be shipped interstate at buyers expense.
pm reply here or call/sms (if i dont answer) 0413544494
thank you for your time.
Edited by whyte
hi mate im intrested in the rims as i req some smaller offset rims. could you be able to measure the width with a tape mesure and let me know by pm.
thanks brentt.
also how much would it cost to post to wagga wagga or would a arangment be better.
  • 11 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
