Hey Guy
We are organising another shipment of kits from JAPAN for the DMAX Range of Kits, Fenders and Rear Wings.
We have the entire catalogue available to us, which makes it great. For Full Product Listing, see the DMAX Site
KITS
Type 1
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • A31
  • R32
Type 2
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • Levin
  • Trueno
Type 3
  • S13
  • 180SX
  • S14
  • S14a
  • S15
FENDERS
D1 SPEC
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • R32
  • R33
  • A31
  • Levin
  • Trueno
  • FC
  • FD
Front Over Fender
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • Levin
  • Trueno
  • R32
  • R33
  • A31
  • C33 LAUREL
  • JZZ30 SOARER
  • 90 MARK2
  • 100 MARK2
  • 90 CHASER
  • 100 CHASER
  • FC
  • FD
Rear Over Fender
  • S13 - 30mm & 50mm
  • 180SX - 30mm & 50mm
  • S14 - 40mm
  • S14a - 40mm
  • S15 - 30mm & 50mm
  • Levin - 40mm
  • Trueno - 40mm
  • R32 - 20mm
  • FC - 30mm
  • FD - 50mm
WINGS
WINDOW SPOILER
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • R32
  • LEVIN
BOOTLID SPOILER
  • S13
  • 180SX
  • S14
  • S14a
  • S15
  • R32
  • LEVIN
INTERIOR DOOR PANELS
FRP
  • S13
  • 180SX
  • S14
  • S14a
  • S15
CARBON FIBRE
  • S13
  • 180SX
  • S14
  • S14a
  • S15
RRP PRICING
KITS - $1095kit
D1 FENDERS - $495pr
FRONT FENDERS - $395pr
REAR FENDERS - $395pr
WINDOW SPOILER - $330ea
BOOTLID SPOILER - $330ea
CARBON FIBRE INTERIOR PANELS - $750pr
FRP INTERIOR PANELS - $475pr
We are ordering a complete 20 Foot Container, so first in best dressed. We want to have this organised by 31st of August. We need orders and payments by then. If we can do that, each person who orders and makes payment by that date, receives 20% off their order.
Please PM us your order, so we can get this rolling ASAP, as we dont want to delay the supplier anymore than we need to.
Payment Details
Bank: NAB
BSB: 085443
ACC: 573711432
When making payment, please put your name on the payment
Thanks
Tarek
RACESPEC
https://www.sau.com.au/forums/topic/180624-pre-buy-dmax-kits-fenders-and-wings/
can i grab pics of the r32 bootspoiler / wing spolier please.
I'll get a pic of the window spoiler
can u get the interior door panels for r32
They dont make for R32, sorry
Thanks
Tarek
RACESPEC
cheers, wouldnt they have the bootlid spoiler for the r32?
They have both window and bootlid spoilers
hi mate,
what include in the "kits"?
FRONT BAR
SIDE SKIRTS
REAR BAR
Thanks
Tarek
RACESPEC
  • 1 year later...
there is so much stuff i would buy from here if u made it for r33...
r33 is one of the most popular cars and u dont have anything for it its pretty weird.
ide get the wide guards front and rear and possibly the door trims.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
