Hey all
Up for sale I have a few things
1) R33 GTS-t RB25DET head with modified cams. VCT is disabled, has GTR valves and springs.
$600 - No longer sold (Sale fell through)
2) DVD player and screen. Screen: SA-700 LCD SlimArt. is a 7"
DVD is Sansui - DVP-2002B
An FM modulator goes with the DVD player.
Screen is sold pending payment
$130 each
3) Cannon, has 3" entry and 3" exit. Was on my R33 (Which is now for sale) but I didn't like how it looked.
$80
4) 4L60E Commodore gearbox - $65 Comes with torque convertor (Standard) and tail shaft to suit
Contact: Either PM, SMS or call on 0406 962 347
Matt
Edited by MBS206
At the moment, I don't realy want to seperate them
I have the two wiring looms setup together for both the screen and DVD player, and don't feel like seperating them out.
If someone wants to buy the whole lot, but only wants say the DVD player, work it out with the other guys that they buy the screen of you.
Okay, So I pulled the DVD player and screen out, and at the moment I have the two seperated (Looms included)
The FM Transmitter will go with the DVD player.
Asking $130 on each if you want them.
Pic of Cannon PM'd
As for the head, I actually do still have it, as the sale fell through.
I'm waiting to hear back from someone, as to how much they're going to offer.
But PM me through an offer if interested.
Cams, from what I was told, are out of a GTR, they're aftermarket too.
I went back, found all the messages from the guy I bought them from, and they're 252 duration, 10.2 lift.
This is what I was told on them:
after speaking with Ben@racepace and Mattlowth (from sau who is the previous owner) ive found out that the cams are from bens r33 gtr which are 252 10.2 unknown brand as ben had it in his r33 gtr when he imported it... definatley not stock but not too big at that... u dont wanna go much more with hydraulic lifters
he mentioned that also there was alot of work involved to fit the cams into the rb25 head, but Matt the previous owner was insistent on using the rb25 head... the GTR valve springs according to ben just went straight in...
the rest of the valvetrain is standard. stock valves/ports etc etc
in the head/cam package comes
head with cams, polished and chromed covers, 2 speedflow fittings, custom made chrome coil cover, cas etc...
It can be reenabled, but will require you to do some minor work.
IE, open the oil gallery up again.
Will be hopefully getting pics tonight (Depending on when I finish)
i was under the impression that because the rb26 cams run solid lifters the ramp profiles are unsuitable for use in the rb25 head with hydraulic lifters...can you double check the specs mate?
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
