Don't speed and you won't need to know where any of these speed cameras are :thumbsup:
Gotta love wankers like you mate. I've not had a fine in over 12 years except for one, even with several car pulling in excess of 200rwkw, plus a 500hp GTR. I'm also a defensive and offensive driving instructor, and race a dedicated race car.
I'm also only an Engineer with specialisations in guided weapons (using real laser and radar systems) and believe me when I say that these cameras and hand held devices are pretty damn innaccurate, so it isn't a case of not speeding but protecting yourself from their inherent faults.
Don't bother responding, I'm not in the mood for a battle of wits with someone who is completely unarmed.
Otherwise, if you are caught folks try here....
http://www.aussiespeedingfines.com/
I have no other affiliation other than I use their techniques to fight a speeding fine of 64 in a 60 zone. Added to my expertise I have no doubt I will not fail if it goes to court.
FoX is on the money. They are revenue raising and nothing more. Any intelligent human can work that out. 500 million in Vic alone last year. Think of the money not going into the local economy. Greedy Labour govts. Talk to you local member and tell them you will support them if they oppose speed cameras and support real education.
..i lost concentration in the second paragrah somewhere.
but I hate when you approach the redlight/speed camera's and then it turns orange and you're in the position where you decide either to go it.. or quickly, yet legally, hope for the best.. hahah. I faced that life altering decision today in Kambah.. I stopped - would have made it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
