got a few parts lying around that we need to get rid of so here we go.
R32 Bits n Pieces
R32 GTR Wing (black) $100
560kg Engine Stand. Yellow and black $100 (pickup only)
S13 Stuff
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) -$400 {$350 box only}
6. STD S13 Suspension (front and rear dampers and springs) still on car - $100
7. S13 projector headlights with built in yellow foglight - $60
8. S13 Electric Window Control Box (controls all window functions ie auto) [[this is not the window switches]] - $60
9. S13 CA18DET coils. $30 each
10. S13 CA18DE Auto ECU [good for a spare] $10
11. EOI. late model 180 dash with digital odometer airbag model. $400
abs unit off late model 180sx $100
For more info or to buy stuff regarding R32 bits n pieces call Ross [0421 869 037]
To get the S13 stuff call Jimbo on [0405 160 740]
everything is located on north side of brisbane!
Edited by jeffers1987
https://www.sau.com.au/forums/topic/181011-r32s13-sparesmods/
R32 Bits n Pieces
1. Standard Rb20 injectors - $75
2. R32 Fibre Glass Rear Guards - $100
3. Standard Intake Plenum/Runners $100
4. Bilstein dampers and King Springs for front (very low very stiff) $150 (will sell with Gabs for 250)
5. GAB rear adjustable dampers with springs (quite firm) $150 (will sell with bilsteins for 250)
6. R32 GTR Wing (black) $200
7. RB20 Crossover Pipe with STD BOV - $50
8. Highflow RB25 turbo (R34 Compressor) - $500 (still on car available when new turbo goes on)
S13 Stuff
1. JIC Coilovers (6 months old) -$920
2. CA18DE + Auto Box (runs fine - 120rwhp on dyno log dyno) $350
3. CA18DET (in bits) great for rebuild has everything except exhaust manifold/turbo/loom - $200
4. CA18DET ECU - $50
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) - $500
6. STD S13 Suspension (front and rear dampers and springs) good condition - $100
7. S13 2 Eye projector headlights with built in yellow foglight - $100
pm sent regarding hi flo turbo (sold to me pending payment)
Oh prick!! I just saw that and was about to send him a PM.
Congratulations on the buy. PM me if it falls through :D
Free bump :sorcerer:
Thanks,
Abu
Edited by abu
Congratulations on the buy. PM me if it falls through :thumbsup:
Thanks,
Abu
hehe, i was bloody quick , no chance of the sale falling through on my end :D
dump pipe added to the list, damo that cash went in too buddy cheers i will ship the turbo off on monday when i should get a chance to get to aus post. cheers guys
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
