Well for those who remember, i got this turbo of gBay.
http://www.skylinesaustralia.com/forums/in...2896&hl=RX7
So i finaly took it apart, and actually got soem numbers for the compressor.
Compressor Size (mm) : Humm is it the inner or the outer part, Exducere is 70mm, inducer 54mm.
Compressor Trim: 59
Compressor Cover Ratio and what it's off: RX7 front A/R .89 or so i am lead to belive, however i mesured it to be somwhere about .65-.75????
Turbine Size (mm) : Couldn't get the housing off DAM IT. But it's same as slides rear rb25 high flow.
Turbine Trim: as above
Turbine housing Ratio and what it's off:It's an RB25 rear housing high flowed.
As the turbo is in good nick, once i clean it up, and put seals through it to make sure it does not leak.
Would it be ok on an Rb25?
https://www.sau.com.au/forums/topic/181066-my-150-turbo-specs-compressor-side/
sounds like a surge prone sort of turbo.
My guess with a "59 trim" and a largish front wheel, it could be.
hhmmm
My GT3037 is just a little bit bigger than those specs, so this could be closer to a 2835 or something like that, but I wouldn't expect it to perform as well.
Maybe expect about 230rwkw at the most?
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
