Hey forum I just wanted to ask you experts a quick question. I have narrowed my turbo selection to 2 turbos I have a power goal of 500 rwhp can u please assist me by telling me which one you think is better suited for that goal? First up we have the
Dual Ball Bearing GT35/GT40R Turbo T3 style inlet flange with 4 bolt exit. Large TO4S style compressor housing with 4.00 inlet and 2.50" outlet. It is said to have a flow capacity of about 600HP.Turbine-Wheel: 68mm w/ 84 trim-Available Housing: .82 ar, Compressor-Wheel: 82mm w/ 56 trim-Housing: .70 ar and next up is the Garrett T3/60-1 COMPRESSOR SPECS - T04S housing flow: 61 lbs/min 781cfm .70 A/R housing 60 TRIM wheel TURBINE Specs - T3 76 TRIM stage 3 Turbine wheel. Oil lubricated center section. 360 degree thrust bearing .82 A/R said to be Capable of 600whp! All help is appreciated thanks in advance. Oh I forgot to mention it will be a street car so I would prefer the quicker spooling one. Thanks again!
https://www.sau.com.au/forums/topic/181248-hp-goal/
bit hard to read there, but as it is a gtr with a twin setup, for the low power goal of 500bhp, I would stay away from going for a single.
Pretty much anything will make what you're after.
Twin 2530, maybe even twin 2510, n1, gtss....
I was going for a medium to large single because I wanted to cut back some of the upgrade cost? Whats the problem with going to a single from a twin turbo setup if I am only after 500 bhp? Yea its 500 for now but you know how that goes only until i get tired of it and then it will be 6 and 700 bhp cause I plan on having this ride until either it or I die God spare my life and I am just setting up the ride for future upgrades if necessary. So this will just be the initial upgrade.
https://www.sau.com.au/forums/topic/181248-hp-goal/#findComment-3294661
Going for a single isn't going to decrease the upgrade cost. Once you factor in the cost of exhaust fabrication and intake fabrication, new oil/water lines etc, going to a single will cost you more.
The price for twin kits e.g. 2530 are very reasonable. As they are basically straight bolt on, there is almost no customisation/fabrication cost
Also, I feel that there is no need to move to a big single. Larger twins are perfectly capable of putting out big power. e.g. the twin 2530 will put out shitloads of power. It was enough for paul and stace to do 10s with it.
Twin gtrs will make more power again.
Edited by MANWHORE
https://www.sau.com.au/forums/topic/181248-hp-goal/#findComment-3294834
Couldnt agree more
https://www.sau.com.au/forums/topic/181248-hp-goal/#findComment-3294903
One more turbo question before I go. If I opt for the single and go with a T04 turbo say this one the gt 4088r first of all will it fit under the hood of a gtr without mods and secondly if i got the turbo with compressor:wheel diameter of inducer:63.5mm exducer:88.0mm, trim:52, a/r:0.72 and turbine: wheel diameter: 77.0mm, trim:78, a/r:0.85 will this be a lag monster or will the spool up time be just as long as a gt3582r with compressor a/r .70 and turbine a/r .82?
https://www.sau.com.au/forums/topic/181248-hp-goal/#findComment-3295082
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
