  • Replies 160
Posted Images
Sorry for the noob question - but can anyone confirm if there will be a printout rather than just on screen display and explain the basic run through of the set up and whats involved? Have attended dyno days before as a spectator but never payed too much attention to the precautions, whats required of the car and what not....
Cheers
You rock up, make sure you're paid up, get a place on the list, make sure you line up ur car when it's meant to be dyno'ed, stand back and watch them rev. Get your print out (I've never seen a dyno day without print-outs, please confirm John), you look at your printout and go 'hey! xxx kw, not bad!' and then 1 week later you wonder what you can do for more power :cheers:
Cheers
Hey Towlie,
Yes you will get a printout.
We do a quick check to make sure the car doesnt run lean then we do 2 power runs and give you a print of the power.
The print will display power, you AFR and Boost.
If you would like to know anything else just ask.
Regrads,
Cristian
Cristian,
RE the printouts - I've seen some with kW/AFR/Nm plotted against RPM and speed. Engine speed doesn't really mean too much to me (mechanical neophyte), whereas RPM does. And the last dyno I had was kW + AFR vs RPM. Ideally I'd like kW + Nm vs RPM. Car's stockish, so don't care about boost, feels like it's holding fine to redline. Is that a viable combo? :D
Cheers,
Ben
Edited by sl33py
Cristian,
Cheers,
Ben
Ben,
That can be done but remind me as my memory will fail me by then
Regards,
Cristian
For me personally i think KW + AFR vs Boost is great for anyone wanting to see how safe there mixtures are and if it's over boosting. In saying that it is also cool to know how much torque your car is making and at what RPM your car is no longer making peak power, speed means nothing as far as i am concerned.
Cristian: Cool, I'll remind you.
I agree leech, but the only mod I've got is full exhaust/cat and it's been running healthy for the past 2 years (yes!: *yawn*), so chances of overboosting are pretty much zip :worship: More interested in torque this time. When I do my first proper mod (ECU in the next 6 months), then I'll wanna know AFRs again :D
that's a great sheet covers everything :ninja: stupid question but how does the dyno know what your tacho is reading. I understand the speed would be easy as the rollers will tell you that but yes bit lost on the rpm.
RPM is generally picked up from 3 different places depending on the type of car.
It will either come from:
A plug lead
Injector
-ve side of coil
For a skyline, will come from the injector easiest way.
Regards,
Cristian
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
