Up for sale is a set of 6 s15 injectors. Perfect upgrade for an r33 direct replacement, no mucking around. Good for at least 250 rwkw maybe more dependng on set up.
asking $400 ono plus delivery
Pick up also welcome - southern Sydney
Edited by SexyPete
https://www.sau.com.au/forums/topic/182065-fs-s15-injectors-x6-full-set-440cc/
Up for sale is a set of 6 s15 injectors. Perfect upgrade for an r33 direct replacement, no mucking around. Good for up to 300 rwkw.
asking $400 plus delivery
interested, pm sent
300rwkw ?!?!?!? :P keep dreamig mate, u'd be really pushing it to go past 250rwkw. The stock ones are 370cc and max out at around 200rwkw. Better check ur facts before making outrageous claims.
For 300rwkw u'd be looking at 555cc
Edited by Taso84
300rwkw ?!?!?!? :( keep dreamig mate, u'd be really pushing it to go past 250rwkw. The stock ones are 370cc and max out at around 200rwkw. Better check ur facts before making outrageous claims.
ive got 370cc and have 256rwkw
yeah, it is probably not impossible to get 300rwkw if you engine is running efficient and tuned well with supporting mods. Oh and probably a slightly happy dyno.
300rwkw ?!?!?!? :) keep dreamig mate, u'd be really pushing it to go past 250rwkw. The stock ones are 370cc and max out at around 200rwkw. Better check ur facts before making outrageous claims.
mate im pushing 240 rwkw with standard injectors u mite want to get your facts rite before you post.
haha, yea u prob could get 240rwkw on stock injectors running 100% duty cycle and 13AFR.
I should prob have specified the obvious for people like you iLEC, that what i meant was: 250rwkw would be the limit you would get running 440cc on an rb25 safely. By safe i mean 12AFR and 90 - 95% duty cycle.
Sexy Pete,
What S15 exactly are these injectors out of? ADM/JDM Manual/Auto?
Edited by Taso84
The injectors are 6 of the ones in the photo, i just took a photo of 2 though. They are definatly out of a manual s15 turbo. Not sure wether adm or jdm but from other posts on this thread they both are a direct fit into an r33.
Sexy Pete,
Running over 240rwkw with stock injectors for over a year now. Safe, yeah it sure is
Yeah, that's right though.
The advertised rating is under certain perfect conditions i believe and isn't always the same as what you get on the car.
Just the way these babies are.
For an R33, expect 440-450cc definately without an upgraded FPR
Even more with the FPR of course
  • 3 weeks later...
lol, i got tired of trying to find them so, now im actualy importing these, i can get 6 s15 manual maron injectors for 400 if anyone wants them pm me, i can get as many as you like dan. 0405233458
hha one minute u say you want them then you turn around half hour later saying that you going to import them and sell..lol looks like a major hijack here!
lol, im impatient, i went looking all through the forum and no one has any s15 injectors and i want them now... so after i made the post, i got a source that i can get them really cheap from, then i though hey ill do you guys a fav and make them available if anyone wants to buy them i can get them.... no hijack its jus that alot of ppl want them like me, but i wont wait i want it now.
You searching the wrong forum, that's all.
They are rare here
More common on Boost Crusing and other SR20 sites, nissansilvia.com etc
Seen a few sets on boost cruising in the past but that was over 6 months ago....good luck :whistling:
Mine are going strong on about low 80% with 245rwkws btw
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
