Hi Guys,
as topic states, part number is nsk-7056hdcb.
The clutch is still in the box, was going to be put into my 32.
Need to get rid of it soon.
I wont send this anywhere, buyer to pick up from Dandy or if in
neighbouring suburbs i might drop it off.
$450.00 ono
Dont hesitate to call me on 0431 423 170 if you have any
further questions
https://www.sau.com.au/forums/topic/182748-brand-new-exedy-clutch-r32-melb-se/
Oh was interested in this, but its cusion button, I'm after just a brass button.
Just for anyone else interested, its a Heavy Duty Cushion Button Kit, good for about 260rwkw :)
nsk-7056hdcb. (HDCB = Heavy Duty Cusion Button).
Free bump mate, good luck with the sale.
Abu
dont worry, just buy it abu lol
someone must want this though
Tempted mate lol
But there tad cheaper from a trader on the forums, SLIDE.
Plus the cusion button is more expensive then a brass button, but the brass button can take more power lol
Hence why I'm leaning towards a brass button.
Edited by abu
Tempted mate lol
just to clear this up, the ones slide is offering uses a generic pressure plate, now im not sure if this guy had the slide package for sale or the genuine package, but there is a big difference. i bought a genuine excedy package off kudos which cost me a touch over $500 plus delivery, if this is the same package its a good deal, save $50 for the same product and i certainly would have bought this if it was for sale a while back.
EDIT: owell its sold now so doesnt matter haha
nah no dude dont deal much with slide. its from exedy through one of their distributor- orginal exedy pressure plate, i think it was pink lol
thanks
enjoy the fun ull have from the bite of the clutch-
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
