Item:
rb30 ross toughbond balancer, brand new never been fitted $420
rb25det head, very good condition, complete $450
brand new gtr n1 oil pump still in plastic, $375
gtr t28 off r33, good condition $sold
rb25det block $80
rb25det crank standard $sold
rb25det stainless manifold t3 flange, external gate provision $220
r32 gtr larger rear diff cover, holds extra 1L oil $25
rb25det stock exhaust manifold $25
180sx tail lights set $120
brand new sr/rb oil filter relocation kit with thermostat and oil cooler, b&m brand $300
s13/180sx strawberry guards, bit rough $120 pair
s13/180sx ca18det brakes $100 set
180sx rear hubs with shafts $50 pair
r180 open wheel diff $20
Item Condition: new and used
Reason for Selling: no longer need
Price: see above
Extra Info: nup
Pictures: not really no
Contact Details: pm or phone/sms on 0424616244 Bails
cheers
Edited by meatwagon
https://www.sau.com.au/forums/topic/183029-buy-my-bits/
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
